MJC6125
- Apr 9, 2017
- 120
I wanted to get some opinions on this subject. If you have a wood stud wall with studs spaced at 16" oc supporting trusses spaced at 24" oc, what is the proper axial load to design those wood studs for? Would you design them for a 16" tributary load or would you design them for a 24" tributary load assuming if a truss lands directly on a stud all of its load will go to that stud and not distribute out to the adjacent studs at all?
If you are designing for the stud spacing tributary, what exactly is the mechanism that transfers the load into those adjacent studs? Though the sheathing kind of like a load corbelling in a masonry or concrete wall?
I searched through past threads on this topic, but most of the ones I found were more focused on whether the dbl top plate can span between studs if the truss lands at midspan of the top plate. Obviously that would also be a case that needs to be checked.
