borobam182
- Mar 3, 2015
- 50
Hi guys.
I'd just like to run something by you if you don't mind. I feel like I know what the answer would be but I just want some expert confirmation before I make someone spend some money.....
We've got a 2.5" class 300 RFWN flange. Bolt hole in these flanges is 7/8" as per ASME B16.5. In my piping specs, I called off a 3/4" bolt. My spec then disappeared into the drawing office and I never saw it or heard about the job again.
Now months down the line, the drawings have been done (I wasn't given them to check), materials have been purchased and site works have begun.
I've been asked why did I request M16 bolts for these flanges - they don't fit, they're too small, the nuts are almost going through the holes, and why did I do this?
I'm a bit confused - I requested 3/4" and that's what should have appeared on the drawing. After checking the drawing, the draughtsman has ignored my spec and calls off M16's and now I'm being asked to approve this change. They are wanting to use washers both sides of the flange hole to provide a surface for the bolt and the nut to hit, but, I'm not happy with this. My preference would be to buy new hardware because having smaller than specified hardware on a flange connection of this pressure isn't safe. And using washers in this way, in my opinion, isn't recommended.
Do you agree?
Any input would be appreciated.
Thank you
Craig
Do you agree?
Thank you
Craig
