NOTES:
1. STATEMENT ONE.
2. STATEMENT TWO.
3. STATEMENT THREE.
I’ve searched through the Y14 policies and a general web search, but haven’t really found anything that addresses this. I’m wanting to formalize this process where I work, which tends to be a wild west on things because something isn’t documented. What’s the standard or acceptable practice/method for using indented notes, and flagging them? In the past I’ve just avoided using indented notes, but that can result in a lot of repeated text/instruction. The only thing that I can think of is to use different flag symbols, which might be limiting, depending on how many symbols are used.
Referring to the example above that not all sub-statements need flagged just the ones that are BOLD, and that each line is applicable to different areas of a part, assembly or installation. Should the flag symbol be placed at the top level note statement, (3 or 4) or at the indented level sub-statement (1, 2, or 3)?
And then when placing the flag on the respective drawing view, what text to enter in the flag symbol, (3.1, 3.2, etc)?
In Solidworks, either way will require manual entry and result in breaking the parametric function, which is one thing that I’m trying to avoid doing.
1. STATEMENT ONE.
2. STATEMENT TWO.
3. STATEMENT THREE.
1. SUB-STATEMENT THREE.ONE.
2. SUB-STATEMENT THREE.TWO.
3. SUB-STATEMENT THREE.THREE.
4. STATEMENT FOUR2. SUB-STATEMENT THREE.TWO.
1. SUB-STATEMENT FOUR.ONE.
2. SUB-STATEMENT FOUR.TWO.
3. SUB-STATEMENT FOUR.THREE.
