Hi, I am working in the manufacturing industry as civil engineer and while inspecting the structure for any integrity issues, i come across very often major steel columns with totally corroded nuts on anchor bolts. It is very hard to replace the columns, as it is expensive and would be major construction work, what suggestion you have if thread profile on bolts can not be restored? anchor bolts are fixed in reinforced concrete at base on ground level.
Usually it is rule of thumb to not use weld on bolts, what options do i have in this scenario?
Thanks in advance.
Thanks in advance.
