Corrosion book recommendations 4
skh382
1
As an entry-level mechanical engineer I'm studying my way up to be familiar with all aspects in the field including corrosion engineering. Can someone recommend me a basic corrosion related handbook? As a design/mechanical engineer I have found myself lost in choosing the most efficiency material. My company deals with both metals and plastics.
Thank you,
Sung Hong
The best sources would be the ASM Handbooks on Corrosion:
These are very comprehensive (and expensive).
Perhaps a lower-price, single volume would meet your needs. Uhlig's is a popular book:
Corrosion Engineering by Fontana is a little older, but a very good book:
Cory
The newer editions of the last book may be by Fontana and Green. Good book.
There are some great books available from MTI. These are good if you work in specific environments (acids and such).
The ASM Corrosion Handbook is now in three volumes.
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
If you have to make a Materials Selection, i'll suggest you also this book, there is also a brief introduction and explanation of the principal corrosion mechanisms and a lot of Materials Selection example with templates that guide you in selecting a Material. I've found it very useful.
Materials Selection for Hydrocarbon and Chemical Plants
hope this help
S.
The document referenced by laner5 is an an outstanding source of information on corrosion. The galvanometric series on metals in seawater alone is worth a star.
All excellent recommendations. For a best single volume, I recommend Handbook of Corrosion Engineering, 1139 pages (2000) by Pierre R. Roberge. Covers both science & applications (all the alloys). Has a set of Pourbaix diagrams (Potential vs. pH equilibrium diagrams), for Cr, Cu, Fe, Mn, Ni & Zn, including separate diagrams for oxide forms & hydroxides.
For some freebies:
EM-1110-1-4008 Liquid Process Piping.pdf
EM-1110-2-2704 Cathodic Protection Systems for Civil Works Structures
EM 1110-2-3400 Painting - New Construction and Maintenance (30 Apr 95)
TB 43-0213 CORROSION PREVENTION and Control including Rustproofing for Vehicles (1990)
TM-1-1500-343-23 AVIONICS CLEANING AND CORROSION PREVENTION CONTROL
TM-5-622 Chapter 7 -- Steel Structures & Corrosion Protection
[lots more if one cares to browse or search]
MIL-DTL-14072E Finishes for Ground Based Electronic Equipment
MIL-HDBK-1110 HANDBOOK FOR PAINTS AND PROTECTIVE COATINGS FOR FACILITIES [aka UFC 3-190-06 Protective Coatings and Paints.doc]
MIL-HDBK-132A PROTECTIVE FINISHES FOR METAL AND WOOD SURFACES
MIL-STD-7179 FINISHES, COATINGS, AND SEALANTS, FOR THE PROTECTION OF AEROSPACE WEAPONS SYSTEMS
MIL-STD-889B [also Notices 1 & 3] DISSIMILAR METALS
