romke
Automotive
- Dec 13, 1999
- 435
I have come across a question about a cooling system where I actually have no clue what the best answer might be.
It concerns a very large (>500 m3) industrial closed loop cooling system that originally was filled with water from a local source 1:1 mixed with a "classic" type automotive antifreeze (NAP-free). After some time in use (meaning about 5 years) there was a major incident necessitating the need for a "top up" of about 50 m3 - which was subsequently carried out by using a modern automotive ready made coolant (1:1 water/glycol with a organic based inhibitor package ("OAT"). A few years later again the company felt the need to have the fluid analyzed, although no specific problems were encountered. The firm that carried out the analysis and the sampling reported that the coolant mixture contained virtually no nitrites and that thus the system was in acute danger of corrosive attack. That firm promptly delivered a nitrite based inhibitor that was consequently mixed with the coolant already in use for years, bringing the nitrite content up to around 1500 ppm - ignoring the fact that both the original antifreeze and the later added ready made automotive coolant did not contain any nitrite on purpose....In the meantime the system performance has gone down a bit to the extend that on hot summer days the cooling capacity can no longer transfer all the heat to the surrounding air, so the underlying amount of processing has to be temporarily reduced.
Since I am fairly familiar with automotive cooling systems and the type of fluids used therein, I was asked what type of testing would be suitable to verify the state of the coolant fluid and if done so, what could be done to correct eventual deficiencies in terms of corrosion protection, scale prevention or freezing protection.
Frankly I have no idea what kind of testing would be appropriate here. Of course the usual physical and chemical tests can be run, but then? You will end up with a bunch of data, but since there is no clue as to what the fresh data were and how these have been influenced by the addition of a totally different coolant and a supplementary inhibitor, there is no way to tell whether the present composition needs any correction, although it most likely does after a few decades of use.
My initial suggestion to drain and inspect the system, clean when needed and fill with a mix of suitable water, glycol and a inhibitor package from a supplier not only knowledgeable on water treatment in this type of cooling systems but also able to analyze samples, understand the results and make sensible suggestions as to what to do when corrections are needed, was not exactly met with much enthusiasm. I can understand that: it would take a lot of time and be very costly, not only because of the cost of water, glycol and inhibitors, but also a very large amount of waste water needs to be discarded.
Question 1: Do you have any suggestions on how to analyze this mix of different fluids and components and how to arrive at conclusions and maybe measures for correction?
They have plans for building two similar plants that will also contain two very large closed loop cooling systems.
Question 2: Has anyone suggestions what kind of inhibitors would then be used best in the water/glycol mix, given the fact that steel and Al protection is needed, that the maximum coolant temperature will be around 70 degrees C and on which regular meaningful checks on coolant composition can be carried out?
Although these systems have a lot of similarity with automotive cooling systems (closed loop), the operating requirements and the sheer size call for a different approach. The idea is that the coolant need not be changed (automotive systems on modern fluids every 5 years), must give very long term protection (decades!) whereas a car or truck usually changes ownership after 5 years or so thus neither the first owner nor the manufacturer worries when corrosion results in the need for repairs, the inhibitor should be substantially cheaper then the pricey "OAT" complexes etc.
Any suggestions you can come up would be highly appreciated.
