i need to know, what is the most corrosive resistent stainless steel. we are debating between 316 and 304. 316 is subject to more pitting and crevice corrosion. also what is the best method of testing them. we need to determine about how long they will go without corroding.
as to what we plan to use this for, it is used to hold gears in a water motor that run a lawn sprinkler. it will be in a water motor that will be submerged in water (all types) for lenghts of time. i read that the sea water (fog) test is the best method. i also need to know if this test is best and how long should you run this test for.
