I've done some research through the forum and have found some helpful information but am looking for some more guidance, if possible. Below is a brief description of the assembly and conditions as well as a few questions.
- A356 cast pressure vessel with an A380 cast lid. The A356 vessel will be blind drilled and tapped for the fasteners to secure the lid. This is not a nut/bolt assembly and therefore cannot be isolated with sleeving and washers.
- 18-8 or 316SS fasteners will be used to secure the lid into the vessel.
- I'm looking to have both aluminum parts hard anodized.
- I'm looking to use Heli-Coil threaded inserts in the tapped holes.
- Thread size will be 1/2-13 or larger, pending completion of joint analysis.
- This is in a fairly well protected, but outdoor environment. There is a small risk that the entire vessel will be submerged in rain water. In some locations, this water could potentially contain road salt - however, in cold conditions its unlikely enough water would be present to submerge the vessel (because cold, but I suppose it still could happen. In most cases, though, this will be in a relatively dry environment.
I've found some references in other threads on this forum suggesting a thread primer could be used to reduce chance of corrosion and other posts mention that if the amount of aluminum present compared to stainless is high, then the risk of corrosion is reduced. Does anyone have any suggestions or guidance on how to proceed and what to specify? In reference to the amounts of different material - in the entire assembly there is approximately 26 times as much aluminum than stainless, by material weight. I'm not sure if this is considered a lot of aluminum in this scenario or not.
Thank you
Thank you
