I have two choices for some shafts that some linear bearings will run along. The parts will be immersed in a saline solution at 98 deg F for 14 days. I have both 440C and 17-4 hardened shafts readily available. Any guesses on whether either I should expect corrosion of either stainless steel alloy. If so, is one material more prone to corrosion than the other in this environment.
I quickly perused a bunch of galvanic series charts, but didn't find any listing 440C and 17-4 stainless in comparison to one another.
