I recently took a volunteer position at my community's small UF WTP (850gpm total) where all equipment is in one large room. The facility is only 10 years old. Hypochlorite is generated from a small skid on site, at 0.8%. The solution is stored in a vertical tank which chronically leaks hypo solution all over the floor, likely from a cracked tank outlet bulkhead. There is a strong chlorine odour (which I understand to be the odour of hypochlorous acid vapour).
Every piece of electrical equipment not in a gasketed enclosure shows signs of extensive corrosion. Even the keys hanging from storage cupboard locks look very corroded. I am worried about mass failure of electronic and mechanical equipment such as local control panels and valve actuators having been exposed to what appears to be a very corrosive atmosphere.
My question is whether hypo leaks and spills are known to cause a corrosive atmosphere which can result in this level of equipment corrosion? Apparently during commissioning 10 years ago there was an HCl leak as well, which may have contributed to the situation.
