sbowman
- Jan 11, 2007
- 2
I have cosmos designstar 2006. I am trying to use the contacts to analize stress on an assembly of parts. I believe I need to set the global contact as "Free". Then create surface to surface contact sets between components. This just fails.
I thought maybe my parts are to complex, let me try simple parts. so I made two blocks, one goes in the other. Think of a tongue and groove connection. I set up the same contacts. Creating surface to surface contact sets on the top of the groove in block1 and top surface on block2. The same was done on the bottom of the groove to the bottom surface of block2.
I restrain block 1 on the side opposite of the groove, allowing the whole block to flex under stress. The force is applied to a load pad on the top of block2. These two simple blocks also fail.
Does this software package do this analysis? Do I need an upgrade? Or am I doing something obviously wrong? Thanks for any help.
