Hi
I have a steel staircase that was created in Inventor and saved to STEP and imported to Designstar.
My problem is that I cannot get several different parts to bond to each other, even though I´ve changed the model so they are a "perfect" match. I ve tried all the different options, the only one that works is rigid connection but it means that the result are sligtly off. But this only works in static, and not nonlinear analysis. "Surface" works but means that everything just slides along the center beam.
It´s seems stupid that the only way to make sure you dont have a contact problem is to build your model as one part when you want to analyse it, (God I hope i´m wrong).
I think I have read all the help files and searched severel forums to no avail.
Please make me sleep well again .
Mads
Mads
