Hi all,
I'm looking for a calculation procedure to find the minimum flow through the coil and the minimum heat loss required to avoid freezing of water in the coil for a closed circuit cooling tower. as a maintance procedure during winter season
inlet water coil temperature of 50ºF, outside temperature of -10 ºF ambient with 45 MPH wind
Many thanks in advance.
