Counterbore control 1
ewh
Aerospace
Mar 28, 2003
6,147
(a tangent continuation of thread1103-197198)
For a counterbored hole feature with a positional control FCF, is the base (flat) surface of the counterbore controlled by the FCF?
We are attempting to get our MBD definitions in line with what a CMM can consume. A CMM vendor has told use that the bottom of the counterbore is not considered a controlled surface relative to the FCF.
TIA!
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
Flat surface of the counterbore is not a feature of size, therefore position FCF can't be even considered applicable to this kind of feature.
tim_member beat me to it. ASME does not allow application of a position control to a non FOS planar feature (ie: the flat bottom of a counterbored hole), so my answer would be no.
Obviously a depth can be specified next to the diameter dimension, however it would be separate from the position control.
Thanks! I should have realized that!
We'll have to dimension the depth separately instead of relying on the feature definition provided by NX.
-Dalai Lama XIV
Typo, corrected to CMM (Coordinate Measuring Machine)[morning]
-Dalai Lama XIV
