switchdip
- Jun 16, 2008
- 4
Are there any consequences to coupling a generator to a large transformer? I have seen past postings that indicate this is a great way to eliminate inrush, but are there any factors that may be detrimental to the generator.
I am going to be supplying temporary power with (4) 2 MW – 480 Volt generators feeding a 13800 Volt bus. Each generator will have its own 2500 kVA transformer and a normally closed 15 kV switch on the high side. The main issue is that the 13800 side will be connected to a 30 MVA transformer. That is why we will start the first generator directly coupled to its transformer. When that generator is on line, we will sync the other 3 generators online.
I just want to make sure that there are not any issues on the generator alternator that I need to be aware of by energizing the transformers this way. I will slow down the soft starting of the voltage regulator to try to cut down on voltage overshoot.
Have also enclosed a simple one-line.
Any suggestions or comments are greatly appreciated.
