pepette
- Mar 20, 2007
- 8
Hi all,
I am using Ansys classic to model the mecanical behavour of a membrane. The assembly is composed by a strongback (it looks like a square mesh), in this part, a thick film of polymer is glue and a pressure is applied.
So to model with Ansys the mechanical behavour, I use solid element for the strongback and shell element for the membrane. My problem is to model the contact between the membrane and the strongback. I would like to know if it is better to use the CP command or the contact wizard?
The aim of this study is to know the influence of stiffness of the strongback.
Thank you for your help
