Thanks Agent666 for your response.
That s what I also thought. But there s one thing that confuses me:
ACI says in R6.6.3.2.2 that "Analyses of deflections, vibrations, and
building periods are needed at various service (unfactored)
load levels (Grossman 1987, 1990) to determine the performance of the
structure in service. The moments of inertia of
the structural members in the service load analyses should
be representative of the degree of cracking at the various
service load levels investigated. Unless a more accurate
estimate of the degree of cracking at service load level is
available, it is satisfactory to use 1.0/0.70 = 1.4 times the
moments of inertia provided in 6.6.3.1, not to exceed Ig, for
service load analyses."
What I understand from the above is that if we re calculating
period of a building, we can use 1.4 times cracked stiffness of structural
members (except flat plates) which would basically give the properties of
uncracked sections.
Am I right?
Kamil.
