Bjerregaard
- Feb 13, 2002
- 2
We are currently installing a 48-inch diameter sewer (Class IV RCP). The depth to flow line is 15 to 20 feet. Bedding for the pipe is 3/8-inch rock vibrated into place using "concrete stingers". Fill above the pipe zone is native material or import compacted to 90% of standard proctor. About 1 foot of 1" rock is placed below the pipe for foundation stabilization. The native soils are a mixture of sands, silts, and clays. The natural water table is 3 to 4 feet below the ground surface and the working area is dewatered prior to pipe installation.
The problem is that about 3% of the RCP bells are cracking. The bottom third of the bell is cracking and displacing downward. Cracks range from hairline to displacements of 1 inch. Even with close observation of the contractor's installation procedures, we are still seeing cracks. Has anybody experienced similar problems with large diameter concrete pipe?
