ATHAN2
- Sep 2, 2003
- 6
I have been supervising two building projects with basement and I have noticed that cracks on the basement walls are always occurring. This problem always give us a headache because of the delays being incurred during rectification works. We are using PU Grout to sealed it off and prevent the water from seeping through the cracks. We are usually using a waterproof concrete with the strength of 40 N/mm^2, thickness of the wall is ranging from 250 mm to 400 mm. Can you give me an idea on how to prevent this problem? Thank you in advance.
