CScottFlanagan
I'm extending an existing 7-1/2 ton monorail beam. The beam is a "patented" welded plate beam spanning 28' between supports. The existing beam measures 18.75" tall, with a 5/8"x10" wide top flange, a 7/8" x 3 1/4" wide bottom flange, and a 5/16" thick web.
The supplier wants an arm and a leg for this beam and the hangers. Does anyone know a source for this member near southwest North Carolina? I have to match the bottom flange to keep the trolley running smoothley, but the other dimensions are variable.
