In looking at the osha std 1925.550(a)(15)(i), min clearance 10 ft power line. See 1910.333(c)(3)(iii)(A) I have the same 10 ft clearance, but in this case it spells out the clearance is needed if energized and exposed ie bare wire. It futhers states to provide insulation if you need to get closer than 10 ft. My question concerns our over head distribution, we use insulated cables run on a messenger with lashing. One camp is saying 10ft based on 1925.550, the other camp is saying the 10ft rule goes out the window because the line is insulate and cites 1910.333.
I;m looking for opinion, thought or any helpful links that will help us in our debate on how we treat insulated "feeders".
