LeonhardEuler
- Jun 19, 2017
- 200
Working on the analysis of a structure supporting an overhead crane. Runway girder is bolted to bracket connections under the girder and a surge plate is bolted to the top of the girder.
Would it be safe to assume that this runway girder is a "pinned connection" and transfers only negligible moment to the stiffened seat connection and surge plate in all directions besides the "main bending axis" where the stiffened seat is in compression and the surge plate is in tension.
The crane running on this girder obviously has longitudinal, transverse, and vertical forces. I would only be considering moment from the vertical force with this assumption.
