create a cube vba catia v5 1
KABEL
Automotive
Dec 10, 2018
29
MA
hello everyone,
is there any possible way to create a cube using only a point in the space, with vba catia v5.
You can create a user defined feature that takes a point as an input. Then that UDF can be used at your leisure. The documentation for UDFs is in the Part Design documentation.
Jason
you could do that in vba if the code provide the cube direction and dimensions.
Eric N.
jasoncwells
thank you for your response, that's a great idea, the probleme is that I always change the file (assembly) that I'm working on.
itsmyjob
for the dimension I want to set it to 14mm. is there any way to achieve that, I do have multiple points in the space.
thank you in advance,
