Create a lip in 2001
Frankietankie
Industrial
Aug 5, 2004
8
0
0
I cannot find the command to create a lip in version 2001? it is in the book but the program i have running does not display the item in the "tweak" meanu where extruding is used. Cna anyone explain this to me I would like to know how to create one in Pro E
Your config.pro file should be in your Pro E start up directory, do a search in windows to locate it.
Or right click on your Pro E desktop icon, under "short cut" tab and next to "start in" it will tell you what directory Pro E starts from.
Hope this helps
Okay and thank you for all your help, I found the config.pro file, How can I open it? do I have to be in Pro E?
please I am sorry but I am new to this program and your patience is much appreciated.
Bill
pbindahouse@yahoo.com
Open Proe, under Utilities menu select options:
Under "showing" it should show the path to the config.pro file in your start up directory, if not then click on the "open" icon and then browse to where you found it.
Bottom l/h corner under "option" type in "allow_anatomic_features" with a value of "yes".
Click "add/change" then "apply", at the top click "save a copy" icon and save the file. Now click "ok" bottom of page.
Hope this helps
