Create Part List for specific component group only.
robertai123
4
As NX part list will output all the components, Is it possible to create the NX part list for specific component group only.
Just like the Moldwizard ejector pin table which will only output the part list for ejector pin only.
For me, i wanted to output the part list for all the screws (maybe part attribute with value "screw") only.
Hope there is work around for this.
Thanks.
You can specify a certain arrangement. So Make an Arrangement suppress what you do not want in your parts list. What Version of NX are you using? Thanks
It is possible to link the parts list to a view.
I have never needed to use this, but if your component group is their own view then this could be an option.
Jerry J.
UGV5-NX1884
In Teamcenter Structure Manager how do you change the BOM ROW Excluded from No to Yes
Hi SDETERS,
we am using NX6. we have a multiple part list in the drafting. one is for all the components, others for screws, ejector pins.... Currently we one by one hiding the components in each part list which time consuming.
Thanks.
Having used a competing product that makes this easy to do, does the BOM in UG/NX have filters based on component characteristics, such as volume or mass or some part of the description?
Hi 3DDave,
Seems like could not find the part list filter to handle multiple part list, do update if anyone able to find it. thanks
