Create spline nx2..torx head
jbdesign
Bioengineer
Feb 15, 2006
1
I am trying to create a spline representing the top of a torx head screw, where torx tool will fit. I would then extrude. This will be where tool will be inserted.
We recently went to nx2, having great difficulty. help
For torx heads I found this:
It gives some limiting dimensions, but the dimensions of the small and large arcs are unspecified. Anyway, to draw it I would pick a size for the small arc and array it around then do the same for the large arc. Trim as necessary and use the geometry as is; if it really needs to be a spline you can 'join curves' at this point.
