creating a part from an assembly
JDswri
7
I used to use solidedge often and there was a command named "part copy" that would create a part from an assembly. The part would behave just like an imported solid, i.e. no parametric features. Is there a similar command for solidworks?
Sorry if there is a thread that handles this already. Its difficult performing searches for phrases like part copy
If what you want is to save an assembly as a part, then it is that simple, select saveas and change the .sldasm to .sldprt (selectable in the drop down).
SW 2009 SP3.0
Dell Inc. Precision WorkStation 670
4096 Meg, Quadro FX 1400
DUAL DELL 2007FP DISPLAY
Windows XP PRO SP3
You might give "SpeedPak" a try for this. On the "configurations" tab right click on the configuration you want to save as a part and select "add SpeedPak". I think it may be better than the "save as" route.
I use solid works with my engineer and am seeming to have issues in making a sport bottle top to match the threads on my CAD file. This is in regards to thread710-171032. The piece that i need to make air tight is a cap with a male piece on top so i need to add threads to the male piece to match the sport top.
x-2.45
y-2.45
z-1.37
The nominal wall is 0.1
Volume (in^3)
Is this easy to do? Can some one please give me reccomendations?? I thought they were pretty standard.
Thanks alot,
Chris
I forgot to include that the Volume(in^3) is 1.212
Thanks again,
Chris
ezlife123,
Please start a new thread for your question. Tacking your question onto an existing and totally unrelated one, makes for confusing threads.
