Creating A Roll Curve
JMorton
Aerospace
I am trying to create a sliding door that rolls on a mechanism with two wheels. I am having trouble creating the kinematics for it. I simplified the modeling, but am unable to get the mechanism to roll along the rail. I have one degree of freedom but do not know what it is. Each wheel has a roll curve, only one has the command. there are revolute joints from the wheels to the link. The planar joint is between the link and the rail. I have attached a screen grab. The rail is fixed. If I add a command to the second wheel my DOF goes away, but I am unable to figure out a way to make both commands move at the same time. The rail is simplified. The actual rail will have curvature. Thank you if anybody can help me.
Do you really need to see the wheels turning and the door slides on the track? Just make a prismatic joint between the door and the rail, and get on with a more productive use of your time.
How would you make an object follow a curvature with a prismatic joint? It only allows for lines to be chosen.
Part of the reason I need to do the simulation is to view the movement of the assembly to see if it clears a narrow gap the door must fit through. So it must be simulated how the link moves as it goes through the rail. Also it is a good thing to show to demonstrate how the apparatus functions.
From your picture the rail is not curve, should we consider the rail to be curvy?
Eric N.
Please attach a picture showing exactly what you are trying to simulate.
I'm guessing two points that follow a curve will give you what you need, but you'll have to add one or two other joints to keep the door vertical.
