Creating annotations in CATIA V5 parallel to screen via script
RumSam
Automotive
Sep 20, 2018
1
Hi All,
I am currently trying to create annotations in CATIA V5 via a script - I have managed to do normal annotations see script below however I am trying to get the annotation which is created to be parallel to screen?
There is a button in the FTA toolbar which does this - however I need it in script.
Anyone got any ideas?
(I've tried to record a macro however it doesn't pick up annotation settings/properties)
Script so far:
set opart=GetPartFromObject(oParam1)
Set part1 = opart
Set annotationSets1 = part1.AnnotationSets
Set annotationSet1 = annotationSets1.Add("ISO_3D")
Set userSurfaces1 = part1.UserSurfaces
Set userSurface1 = userSurfaces1.Generate(oPoint)
'Above is the point
Set viewFactory1 = annotationSet1.TPSViewFactory
Set view1 =viewFactory1.CreateView(oPlane,1)
Set annotationFactory1 = annotationSet1.AnnotationFactory
Set annotation1 = annotationFactory1.CreateEvoluateText(userSurface1,50, 50, 50, True)
annotation1.text.Get2dAnnot.ActivateFrame catRectangle
annotation1.text.Get2dAnnot.FrameType = catRectangle
annotation1.Text.Get2dAnnot.SetFontName 0, 0, "Arial (TrueType)"
annotation1.Text.Get2dAnnot.SetFontSize 0, 0, CDbl("5.0")
annotation1.TransfertToView view1
oList.valuelist.Add annotation1.Text
Dim LResult1 As Long
LResult1 = Len (oParam1.Name) +4
annotation1.Text.Text = oParam1.Name & " = "
annotation1.Text.Get2dAnnot.InsertVariable LResult1 , 0, oParam1
annotation1.ModifyVisu
annotation1.Name = oParam1.Name
Set annotationSet1 = annotationSets1.Item("Annotation Set.1")
Part1.Update
End Sub
Hi RumSam!
I had the same exact problem. Finally, I managed to write annotations parallel to screen via macros by using CATIA StartCommand and the proper command, "Text Parallel To Screen". Then I used SendKeys function, but with a workaround to avoid the error message regarding lack of permissions and making the CPU wait some milisecs just to give CATIA time to process the sent keys. It's all a bit tricky but it worked for me. I copy the code below.
Hope it is helpfull to you, regards!
'-- CODE!-----------------------------------------------------------------------------
Sub AddAnnnotationsWithKeys(iHB As HybridBody, iHSIndex As Long, iText As String)
'-- Where iHSIndex is the index of the Hybrid shape which the annotation will be attached to and iHB is the Part Hybrid body where it is.---------------
Dim partDocument1 As PartDocument
Dim part1 As Part
Dim selection1 As Selection
Dim skObject As Object
'-- skObject is created only to use SendKeys function without any failure-------------
Dim newAnnot As Annotation
Dim annotationSet1 As AnnotationSet
Dim timeNoF
Dim lTimeIni As Date
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
'-- Target surface is selected and then the annotation command is called---------------
Set selection1 = partDocument1.Selection
selection1.Clear
selection1.Add iHB.HybridShapes.Item(iHSIndex)
CATIA.StartCommand "Text Parallel To Screen"
CATIA.RefreshDisplay = True
'-- A generic text is sent just to create the annotation-------------------------------
Set skObject = CreateObject("wscript.shell")
skObject.SendKeys "text", True
'-- It is necesary to wait around 100 or 200 msecs to give CATIA enough time before "pressing" ENTER-----------
'-- If condition was added just for safety, in order to avoid infinite loops-----------------------------------
lTimeIni = Now
timeNoF = Timer
Do
DoEvents
If Now > (lTimeIni + "00:00:05") Then
Exit Sub
End If
Loop Until Timer > timeNoF + 0.2
skObject.SendKeys "{ENTER}", True
selection1.Clear
part1.Update
'-- Annotation parameters are finally set as desired.---------------------------------
Set annotationSet1 = part1.AnnotationSets.Item(1)
Set newAnnot = annotationSet1.Annotations.Item(annotationSet1.Annotations.Count)
newAnnot.text.text = iText
newAnnot.text.Get2dAnnot.SetFontSize 0, 0, 2.7
newAnnot.ModifyVisu
End Sub
