I am trying to create the parting line for the core and cavity of my mold. Here are the problems i am having.
1. My part is an .igs file that comes in as a surface. It will not solidify because there is a small overlap of two surfaces. I cant figure out how to repair it because the diagnosis fix does not work. Also, if i delete the overlapping face and use either a filled surface or a lofted surface it will not knit together.
2. I cannot get a complete radiated surface all the way around the part by either picking all the edges or using the propagate tangent edges. Both come up with errors. I can get the parting line with about 4 radiated surfaces but not one.
3. If i attempt to knit a radiated surface to a solid part surface file by using the part as the seed, i get the error: the radiate surface cannot subdivide the body.
Any answers to these questions, or any other ideas for creating core and cavity would be appreaciated.
