vantveen
Aerospace
- Apr 22, 2005
- 8
Hi All,
From a double curved surface of a step file I want to measure the position (XYZ) of points on this surface w.r.t. a coordinate system. Either it concerns a large pattern (600 x 600) so also a lot of points (360000). In this way the surface is defined by points which can be used in an other program. As you can imagine creating and measuring points in this manner takes a lot of calculation time. Is there any idea how I can optimise this process? Maybe in combination with MathCAD?
Thanks in advance.
Martin
Thanks in advance.
Martin
