TiagoFigueiredo
Industrial
I all,
I want to create some shortcuts, for not having to click on toolbar every time I need to use a command. I've defined the want shortcut, but I'm quite disapointed with the result. In CATIA for using once the command, we click the command just once. For keeping using it we need to double click it! And with shortcut I'm not able to do it. At least I didn't found of how to do it.
One command that I'm trying to do it, is the "constraint".
Any tip?
Tiago Figueiredo
Tooling Engineer
Youtube channel:
Any tip?
Tiago Figueiredo
Tooling Engineer
Youtube channel:
