Creo Simp Rep
naah
17
Hello
I am using Creo parametric 4.0. I want to know if it is possible to hide parts in the master rep? each time I switched from modified rep to master rep the hiden part shows up automaticlly.
I need to add a part in the master rep but I don't want to show it in the master rep. I want to use it in the other reps.
Please let me know if you have previous experience.
NJ
Thank you for your information.
Is it possible to change the forom to the CREO?
NJ
Unfortunately, no - you can click the "report" button on your first post and type in "wrong forum, please delete this." Maybe you can select your own message and delete it yourself; I haven't needed to do that so I don't recall.
Then create a new message in the forum you like, the Creo forum if it's for this particular question, but there are others for other engineering questions.
