Creo-Sub Assembly BOM
WGarrity
1
I have a drawing of an assembly, which contains a sub assembly, but I would like the BOM for the whole assembly to include the components of the sub assembly. I haven't been able to find a way to do this yet. I have the BOM started for the parts that are not n the sub assembly but can't figure out how to add those last couple parts.
Hopefully there's an easy way to do this without rebuild the whole assembly.
Thanks!
If the BOM is a table on the drawing, then you can set it to be recursive - this will not show the sub-assembly, but will show all of the parts in it.
You haven't said which version of Pro/E you are using, but if you search the help files for repeat region, you can get how to access the menu options - one is for Flat/Recursive/Recursive no repeats.
