Krishna.k
New member
- Jun 14, 2019
- 7
I have a Creo parametric model, Which I am converting to NX parametric model. I had an issue while converting toroidal bend feature in Creo to NX.
In Creo, Toroidal bend feature was created using flowing parameters.
As you see in the above picture, Rectangle was bent about an axis (used as BEND AXIS in Toroidal bend feature) which is not passing thru the absolute coordinate system.
on the right side of picture you can see the output of toroidal bend feature( "Preserve length in angular direction" option in Toroidal feature dialog is turned on so the distance from points on the curves to the plane of the profile section is maintained along the angular direction).
Please see this link for Toroidal feature documentation:
To reproduce this in NX, I tried to use Global shaping by curves feature. But I was not able to understand how to create Base curve and control curve to replicate this geometry.
Could you please help me to solve this problem.
Thanks & Regards,
Krishna
Thanks & Regards,
Krishna
