CRN-TSSA Ontario Canada 1
S_S_IBRAHIM
11
A lubrication system for pumps using oil working pressure = 35 psi , does it require CRN ? in which category the oil can be exempted / classified as per the technical standard and safety act ? as Hydraulic fluid ? or oil for non-fuel application ? or liquid not more hazardous than water ?
Thanks for the reply , thinking about (e) as well but not sure what is meant by liquids not more hazardous than water ?
for ( i) : talking about hot oil piping , the lubrication system consists of pipes, fittings , vessels ( reservoir )shall this apply to ?
for ( m) : no mention for pressure or temperature requirements ? not sure too if this apply to a lubrication system for pumps bearings ?
I would appreciate your comments if possible !
