  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Cropping Problem
Dman5
Automotive
Mar 9, 2011
36
I created an auxillary view and cropped a portion of it because I did not need to show all of the view for clarity. I added a few fillets to the associated model and added nomenclature to the drawing and the previously cropped view is now showing the full view. When I click on the view the box shows the view as cropped.
Any help would be appreciated.
Edit the sketch of the crop and then click the rebuild icon.
What version are you using? I used to see this more often in earlier versions. I would see it with detail views as well... just once in a while.
-Dustin
Professional Engineer
Pretty good with SolidWorks
Thanks ShaggyPE, that did the trick. Appreciate the tip.
