MiketheEngineer
I have two I-beams that cross over each other at 90 degrees - like a cross.
The lower beam is shackled at the ends to the roof and supports the upper beam where they cross - in the middle.
There are no real shear or axial forces involved between the two beams. The upper beam simply sets on the lower beam. The only reason I see to even connect them is to keep everything square and to prevent any side slippage.
I suggested a couple of 3/4'' bolts in opposite corners to secure the beams together.
One of my young engineers is trying to convince me that the moment in the upper beam - which is sizeable will now somehow transfer moment into the lower beam thru the bolts. The upper beam has already been sized to carry the moments and shears generated by the loads on the upper beam.
I am trying to convince him that 3/4'' bolts in 1'' holes will not transfer any moment (or minimal) to the lower beam...
Who is crazy here??
Who is crazy here??
