Cross-Correlation and Phase Difference
dynaman
New member
AU
Hi guys
I'm trying to implement a phase shift meter in VB.NET between 2 audio signals. I'm using Math.NET cross-correlation functions however they can't calculate the phase shift or lag between the 2 signals as far as I can tell. Can anyone recommend a .NET DSP library that can calculate phase shift using FFT cross-correlation methods?
thanks
DM
Are you just looking for the phase part of the transfer function? if so then just use arg(Syy/Syx) where S is the cross or auto spectrum.
Of course matters could be vastly clarified if you included a link to math.net.
Cheers
Greg Locock
Yeah, it's a bit frustrating. I couldn't find anything specific to cross-correlation in that library. From what I understand, this process can be used;
[ul]
[li]take the FFT of both signals[/li]
[li]multiply one with conjugate of the other (element-wise multiplication)[/li]
[li]do the inverse FFT[/li]
[li]get max value as a correlation coefficient and its index as the delay(signal lag)[/li]
[/ul]
I just wish there was a library that had a "find phase difference" function.
thanks
DM
I don't understand your process.
The formula is, where F is the complex fourier transform,is phase((Fx.*Fy)./(Fy.*Fy)) where dot indicates element by element. Perhaps easier for you is that the phase of the transfer function is phase(Fx.*Fy).-phase(Fy.*Fy), which simplifies back to phase(Fx).-phase(Fy). Note that the delay is a function of frequency and is meaningless where there is little signal. The coherence is a useful measure of phase stability.
Cheers
Greg Locock
Hi Greg
Can I please clarify by what you mean when the delay is meaningless where there is little signal? Is there are a better process for measuring phase difference when the signals are small and somewhat noisy?
regards
DM
Yeah. Is there a way to get accurate phase difference measurements then?
Hi Greg
I currently use to perform many DSP functions. There are components in this library that allow FFT operations however, I'm still not clear how to extract the phase difference between 2 audio signals as discussed above?
cheers
DM
SLCarttopolar(SLDividecomplex(SLFourier(signal1),SLFourier(signal2))) should give you the complex spectrum of the transfer function in (mag,phase) format, or you could try one of the other formulations i gave above. there are others, with various deep and meaningful differences, but that's where I'd start.
Cheers
Greg Locock
Thanks, Greg,
I appreciate the guidance. Will let you know how it goes.
cheers
DM
Hi Greg
Just implemented the complex spectrum of the transfer function and plotted phase vs frequency. It seems to work OK if the two signals are sine waves. However one is a sine wave and the other is a square wave (i.e. pulse of 5% duty cycle). It seems to give noisy readings that seem to jump around for this configuration even after averaging results.
Sorry, a bit confused about implementing the method.
regards
DM
So I tried simulating my results using Multi-Instrument Pro (
I can generate essentially the same results for the Phase Spectrum. However, Multi-Instrument has a great Cross-Correlation function which calculates the delay between Signal 1 & Signal 2 even with noise present. I'm not sure how they created that function?
Well I was able to replicate Multi-Instrument Pro's function by applying the method as originally stated;
[ul]
[/ul]
Plotting the Inverse FFT result vs time Delay produces the same result. I think I'm on the home stretch now.
