Martin Gillie
- Feb 6, 2022
- 10
I'd be interested to hear people's ideas on how cross-ridge wind loads are transferred to shear/gable walls in pitched roofs. Two scenarios
1) 45deg pitch with ridge beam and timber frame walls. I am seeing a substantial lateral load on the ridge beam causing minor axis bending, transferred to the supports at each end. Do people design for this? Is load also transferred through the wall plate>elevation>gable somehow? With a steep pitch, transfer through the sheathing seems dubious to me.
2) As above but with raised collar ties. What stabilized the wall heads?
