Cross section formed by several working planes? 1
Patyuchenko
17
DE
There is a need to visualize the nodal solution (temperature) in the cross section formed by several working planes.
If anyone know how to perform this I will be very grateful to you for any help.
Thank you very much.
Hi
You can use the /CPLANE command.
Cutting plane by Workplane.
Grtz
Garry
yes, if you need a section made up by one plane at a time. But there is no way to get a "broken-line" section (or however you may call it) made up by several planes in sequence, if that's what Patyuchenko needs...
Thank you ansysfreak and cbrn for your answers.
Yes, cbrn, you are right, I need to obtain a "broke-line" section formed by several planes. Now I know, from your answer, that, unfortunately, it is not possible in ANSYS.
Hi
Can this marco help you
/seg,dele
/seg,multi,filename,0.05
wpoffs,,,-0.001
plns,volt
wpoffs,,,0.0001
plns,volt
plns,volt
wpoffs,,,0.0001
plns,volt
/seg,off
/seg,pc
This is a macro writen for the result of volt through a sphere, it offsets the WP and makes a picture etc.
All these pictures are then put in a film.
Hoop it helps
Grtz
Garry
Great! Thank you very much ansysfreak. I will try to apply it to my case.
