batter1979,
Sorry if my last post gave offense, I didn't mean to.
The point I was trying to make is that the approach to designing a spline can vary greatly depending on the application. I have designed splines for high-performance, high-reliability, weight critical aircraft drivetrains. And I have also designed splines for cost sensitive, extremely long fatigue life wind turbine drivetrains where weight and size were not critical.
Each particular design had its own challenges. And to be honest, designing a spline for a wind turbine drivetrain that had to operate trouble-free for 150,000 hours with no maintenance and within a modest budget, was more of a challenge than designing the aircraft drivetrain spline that had to last 5000 hours and had no cost constraints.
Having said all that, I would somewhat disagree with your comment "whatever it costs is whatever it costs". The best example of "cost driving design" in splines is the typical spline used in automotive transmissions. These splines are designed with geometry variables like pressure angle, tooth thickness, tooth count, root fillet, etc. that are selected specifically for ease of manufacture using mass production processes like roll forming. The combination of fatigue life, quality and low manufacturing cost that these guys get with a mass-produced spline is truly impressive.
Terry
