Crude oil compression
oillio
Petroleum
Oct 1, 2009
16
Good afternoon,
If I compress crude oil from 1 barg to 25 bars how can I calculate the reduction of volume?
Thank you.
Yes, if you know the bulk modulus of the oil. The problem is that no two crude samples are exactly the same, so getting a bulk modulus can be difficult. You can come close by doing a mass average property calculation since the bulk modulus for each component in crude is published somewhere.
David
if you are able to characterize the oil you can calculate isothermal compressibility k = -(1/V)*dV/dp with a equation of state as SRK or PR (my usual approach with tools as Prode Properties), or the bulk modulus (the inverse of compressibility) as suggested by zdas04, differently you could use generic correlations, see for example Vazquez and Beggs correlations for fluid physical property prediction or Al-Marhoun the coefficient of isothermal compressibility of black oils, there are many different methods and I can't recommend one.
Thank you very much I find the solution.
I do not know why I totally forget this bulk modulus
Thank you.
Here's your excuse. Its usually not taught in schools; more of an on the job learning subject. It is infinitely easier to teach using the theory of ideal uncompressible liquids, kind of like learning statics with Newtonian, rather than relativistic physics.
