mikelangel78
- Mar 5, 2015
- 26
Hello every one,
I've a CT marshalling box that getter 3 CT's (one for each phase).
These box received the wiring cables from each CT secondary terminal box and from that marshalling box it'll be connected the cables that goes to the meters and relays installed in a control house.
To connect the wiring from the outside, the terminals in the marshalling box are located horizontally in a support rail. The terminals are screw clamp and with some kind of slinding bar, PHONEXI CONTACT URTK/S BEN. These sliding bar open from bottom to top. The terminals that received the cables form the CT secondary box have a slinding bar type PHOENIX SB2-RTK/S and the cables that ar going tho the control roomm have a slinding bar type PHOENIX SB4-RTK/S.
From waht I undersatnd this sliding bars installed in the URTK/S terminals have the propose to short-circuit the secondarys of the CT's when they aren't use by a realy or meter, so they avoid that a secondary is opened. And also to test the circuits.
After the CT tests are donne, and if all the secondaries of the CT are used, these sliding bars (SB4) should remain in the open position. Am I right?
Thank you in advanced.
