bashar2008
hi all
i have seen a low tension CT of a ration 400/5 and read that its Ith=20KA
and i wondered how can they specify that short time current level,
as i know it is specified for primary current which it is not built in ct
i mention that i know if the current in primary side risen up it is not the same case for secondary to be response to, as the ct core will be saturated
the ct is window type low voltage 400/5,class 1, 10va
i will be so grateful if any one can help to explain how to specify Ith for LV CTs?
thank you in advance
