Cubic Vessel Design
obriend1
11
I have a small pressure vessel (3" x 3" x 3") that contains a centered 2" dia ID and square bolted end caps. I am assuming that the ASME minimum wall thickness formula in AD-201 still applies, but I am not sure because Section VIII Div 2 does not seem to mention anything about square or cubic vessels. Can someone please clarify the code when applied to non-circular vessels? Do I ignore the extra material that is on the corners and just take the thickness from the ID to the shortest distance on the outside of the vessel?
Look in Div 1 App 13 - Non-circular pressure vessels.
There's bending stress going on - can't just inscribe a circle & call it hoop stress
Arto,
Thanks for your suggestion, but my vessel actually has a x-secton like a square nut (square outside with a hole centered in the middle) when looking into the vessel from the top. Unless I am missing something, the type of vessels in Div 1 Appendix 13 are non-circular ID's and x-sections. Does this still apply to my vessel? Does Div 2 deal with different vessel geometries not listed in D-2?
Your best bet would be to perform a Div 2 Appendix 4 design-by-analysis. You may also want to check out Div 3, I know that a number of their autoclave-type designs may not have circular external dimensions.
Good luck!
If the inside of the vessel ([ponder]) is circular just take the minimum thickness all around and treat it as a circular shell.
Can't say anything about the square bolted end caps, as I don't know the geometry. If you can inscribe in it a flange that may be checked per App.2 then that's OK. Not sure to recall that correctly, but App.2 should have something also about non circular flanges.
prex
Online tools for structural design
I would like to thank everybody for your advice and help. :)
