Steve Shover
I’ve been working on my sons dump truck engine which is a Cummins 855 NT400 Big Cam trying to set the injector timing. This is an FI code and believe the timing should be set at .069 fast .070” nominal, .072 fast. The problem I’m having is in the accuracy of setting this number, I’m using the Cummins dial indicator set up and have even switched to larger indicators to increase accuracy. The problem is detecting top dead center, it seems to have what I think is a large band width for TDC and within that rang I can see the injector lift change by .005/.007. At first my injector setting was all over the place due to this, once I started to always wait for the piston to start down and would see dial indicator movement then re-zero the injector indicator it became very repeatable. Is this typical and does anyone have any suggestion for the best method of setting this and how critical is a few thousandth off. I know it will be advancing or retarding the timing I just don’t know exactly how critical it is. Any help would be appreciated.
