ayjayaych
- Apr 22, 2015
- 1
A meter measures both voltage and current. The instrument is used in a switch-over configuration for mains and a standby generator. The voltage connection for both is fairly straight forward. The current is measured by passing the necessary conductor through the integral CT of the instrument. Both conductors of the two feeds are passed through the CT. Only one feed is read as they are isolated from each other by the change-over switch. When reading mains, the current load is half the value of the generator load reading. What can be the problem?
Anthony
Anthony
