curve to points
ak762
Automotive
Dec 5, 2001
73
0
0
NO
I have got curve with help Curve Through Free Points
Can I get only points in order to create curve or spline by manual. Or convert present curve to points.
Solidworks doesn´t do that. You cannot convert a spline to points, or join points to a spline. What you can do is enter with programming. Make a search in the net for macros.
I hope that helps.
I'm not sure what the actual queston is here,
you can bring in a curve through free points using x,y,z coordinate points from a spreadsheet.
you can convert a spline into equal points if you so need to. For instance if a made a spline with 5 control points and I wanted to break that spline into 20 points, yet still have the control points in tact. This is an API function that you have to write a macro for, I have one if you need it. The only thing I have not been successful with at the moment is making those points update when I change the spline. working on this!
Did i answer the right question? LOL
It's too early in the morning!
Jon Benavides
Fisher Unitech
Troy MI
In Solidworks, there is an icon called "Split Curve" you can find this under the "Sketch Tools" Toolbar. This icon does exactly like it says it will split the curve or spline for you.
There is an Excel program, that you can use to make a spline through free points using x,y,z coordinates. I have never used it, but I believe I seen it at the SW website under their Model Library or
I hope that helps, Scott Baugh, CSWP :)
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
Thank you guys for concern in my question
Fortunately I have other software such Mastercam there I convert ASCII points and edit it. After I create curve as I want then Import to SW. If you will have a time visit and see me at
By the way Mr. Jon Benavides could you send me macro that you mentioned earlier about break spline. I'll try to play with it.
You're welcome,
Yes, i will send you the macro when I get into work this morning.
And to Scott, yes SW has the split curve functionality but you have to manually pick your point locations. The way i am describing will mathmatically break the line into equal sections independant of it control points.
Like i was saying though, its not perfect because I havent figured out a way to keep the points on the curve if I move one of the control poins, I wind up hvaing to re-run the macro...and to me that is NOT acceoptable. If anyone finds out how to do this and have it update with changes, PLEASE let me know how you accomplished it!
Jon
John,
I have a spline that was imported from another program and it is not centered about the origin. I need to find out the extents of the spline, break it into equal parts and get the point on the spline with the highest-x value and with the largest y-value. If you could send that macro to me I would love to see it.
Thanks,
Kurt
kurt@sonsoferin.com
