Ok I just joined and this is my first post. I am using Draftsight 2015 version and it works fine. I came from Autocad 2010 and I have been a long time AutoCAD user. I had a command on an icon in AutoCAD that did copy and rotate in a single icon. I have found out that Draftsight does not have this ability. Ok, I'll deal with that. I was on the 3Dsym site and it was suggested that you could copy the entity in its original position by selecting the copy command, picking the entity and hitting return 3 times in a row. This would essentially copy the entity on top of it self. Then select the rotate icon and rotate the copy as you would normally. This works fine and I am able to copy and roate an entity.
Here is my rub. I want to enhance a copy icon to do the extra three enters on its own. I just pick the enhanced icon, select the entity and hit enter once. Then I select the rotate icon and rotate the new copy which should be sitting on top of the original. My problem is I can't seem to enhance a copy of the copy command to make the new icon work. I am using the ";" as the return or enter in the command, but all it does is end the command.
Anybody got any suggestions or can provide any help? I like Draftsight and for the most part I have been able to figure out how to get it to do the same things I had tweaked AutoCAD to do so it isn't any bit issue. I just have not been able to figure out how to get custom commands in the icons to work for me.
Gary
Gary
